Heterogeneous networks and multivendor environments make it challenging to juggle multiple dashboards when checking a device's status or health. Traditionally everyone uses APIs to build their dashboards and customize them accordingly. APIs, however, have their own drawbacks, like the limitation on the number of API calls per second, broken base URL, or API gateways. This is where HPE Aruba Networking UXI Data Push Destination comes in. It is a next-generation methodology to transport data on different storage platforms. With Data Push Destination, customers can use directly available connectors like AWS S3 and Google BigQuery and seamlessly integrate between UXI and any supported third-party storage.
UXI’s Data Push Destination feature supports multiple endpoints or storage systems like Google BigQuery, Elastic Search Cloud, AWS S3, Generic HTTP endpoint (ServiceNow, SumoLogic, PagerDuty, and so on), BigPanda, and Splunk.
Taking automation and data collection to the next level
UXI sensors continuously test networks and applications from an end-user perspective and report the results to the UXI dashboard where the results can be viewed at a glance. With Data Push Destination, customers can achieve the following benefits:
- Create custom reports and summarize test results over a time-range that you can specify and control.
- Build custom dashboards on external platforms to visualize the test results along with that of other network and application monitoring systems.
- Perform ad-hoc analysis and look at the data in diverse ways and troubleshoot issues in more detail.
UXI’s Data Push Destination feature allows you to configure your UXI dashboard to send test results, issues, and incident data to a destination that you manage.
Find more data push destination examples in UXI’s developer hub.
Watch why UXI is your non-negotiable digital experience monitoring solution!
© 2019 Google LLC All rights reserved. BigQuery is a trademark of Google LLC. All third-party marks are property of their respective owners.
