Close
HPE Aruba Networking Blogs
Factory Reset Your Aruba Mobility Controller
By Rene Jorissen, Blog Contributor
With ArubaOS 8, a new appliance is introduced: the Aruba Mobility Conductor. An Aruba Mobility Conductor appliance enables full centralized management in a controller-based environment and adds some awesome features. More information on Aruba Mobility Controller can be found here.
A Mobility Conductor appliance takes care of all the control-plane features within your deployment and provides better user experience, flexible deployment, simplified operations and enhanced performance.
Mobility Controllers are added to the Mobility Conductor as regular controllers and all configuration for the Mobility Controllers is done on the Mobility Conductorconsole to provide centralized management.
The question arises: is it as easy as it was to factory reset a Mobility Controller managed by a Mobility Conductor?
The answer: yes it is, but you need to take one extra step!!
I took a Mobility Controller from the shelve and wanted it to get it configured as a standalone controller with ArubaOS 8. The controller was running 6.5 code, but the backup partition already contained an 8.0 code image and was previously managed by a Mobility Conductor during a workshop. I upgraded the 8.0 code image to the latest 8.2 code image and booted the controller from that partition.
I tried to log in with the credentials from the 6.5 code, but that wasn't working anymore and I had no clue with credentials were used during the 8.0 workshop. So I started with the default password recovery which is very simple and straightforward. Connect to the console with username "password" and password "forgetme!".
Normally, you would configure a new management user and "write erase" the configuration, but this is by default not possible in this scenario. Once you enter "config terminal" you receive the following message.
(controller) *#configure t This controller is managed by a Mobility Conductor. Configuration changes can only be performed on the Mobility Conductor.
Okay, so maybe I can do a "write erase" directly….
(controller) *#write erase All the configuration will be deleted and the controller will be reloaded. Press 'y' to proceed : [y/n]: y You do not have permission to execute this command
No, so what's next? The clue is the command "local-config enable"
(controller) *#local-config enable Warning: 'local-configure enable' should only be used for debugging. This will disableAuto-Rollback feature. Please use the command 'local-configure disable' after you are done. Configuration Mode Is Enabled.
Now you have the option to enter "config terminal" and add a new management user, log in with the new user and "write erase" the configuration. Next, I rebooted the controller and started with a fresh, factory default controller with ArubaOS 8 software.
(controller) *#configure t Enter Configuration commands, one per line. End with CNTL/Z  (controller) *(config) #mgmt-user admin root Password:************ Re-Type Password:************ (controller) ^*(config) #end (controller) ^*#write mem  Saving Configuration…  Partial configuration for /mm/mynode ———————————— Contents of : /flash/ccm/partial/0/p=sc=mynode.cfg mgmt-user admin root d442d5b0011f409d930efc3f1a4409d5abb80c1a47e5247626 Configuration Saved. (controller) *#exit  User: admin Password: (controller) *#write erase All the configuration will be deleted and the controller will be reloaded. Press 'y' to proceed : [y/n]: y Write Erase successful  System will now restart!
I hope you have found the blog useful and reach out with any additional questions on the community or on Twitter @@rene_booches
